TractorLinks.com
Tractor Talk Discussion Forum
Re: calling Adirondack case guy....? for you
Adirondack case guy
10-01-2013 14:31:08
Glenster,
Early 400s didn't have a brake. on later ones there was a triger on the lever that locked the lever against a brake. You could Try loosing the clutch pack a notch or two to open up the discs if it doesn't have the lever with the triger.
Loren
Adirondack case guy
10-01-2013 14:43:06
 Re: calling Adirondack case guy....? for you in reply to Adirondack case guy, 10-01-2013 14:31:08
Just an added caution. An auger shouldn't be much of a load, but be sure if you back off the adjustment a bit, and you are running a big auger which works the tractor, you could slip the clutch pack and warp the plates so it will not stop on anything with a light load.
Loren
glennster
10-01-2013 14:54:21
 Re: calling Adirondack case guy....? for you in reply to Adirondack case guy, 10-01-2013 14:43:06
he is running a 10x62 mayrath with a swing away. it outa make the 400 snort a little!! thanks for the help!!!!!
