TractorLinks.com
Tractor Talk Discussion Forum
Re: 6volt conversion
Russ Crawford
09-26-2013 16:21:53
I found the raised numbers and I have them hooked up correctly. Anyother ideas? Thanks Russ
Janicholson
09-26-2013 20:26:04
 Re: 6volt conversion in reply to Russ Crawford, 09-26-2013 16:21:53
The diode bridge inside the alternator (not the regulator, which is separate) can be conductive both ways if bad or going bad. The check it take out the two small #2 and #2 terminals. Remove the wire from the big stud and put a volt meter between the stud and the wire terminal. If it reeds less than 1/4 volt it is probably OK. If more it is an indication of a bad rectifier bridge. Jim
Russ Crawford
09-27-2013 08:42:52
 Re: 6volt conversion in reply to Janicholson, 09-26-2013 20:26:04
Thanks to everyone who has taken the time to share their knowledge. Russ
old
09-26-2013 19:12:57
Could be a bad new alternator seen that many times over the years and seems to be getting worse now days
