Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: 6volt conversion
Russ Crawford
09-26-2013 15:50:10
I was not sure how to tell was the # 2 wire so I hooked it up like the picture with the #2 wire on the right facing the back of the alternator. The alternator does charge when the engine is running. Thanks for responding. I hoped you would. Russ
soundguy
09-26-2013 16:51:24
 Re: 6volt conversion in reply to Russ Crawford, 09-26-2013 15:50:10
DEFFINATELY ensure you have #2 tot eh charge stud, and #1 to the SWITCHED side of your ignition
old
09-26-2013 15:56:59
On the alternator is self there is raised numbers that are #1 and #2. As far as which is which I do not know but if you have the 2 wire plug that you buy at say O'Reilly's I could go out and look and see which wire/color is which
Jon Hagen
09-26-2013 19:55:22
 Re: 6volt conversion in reply to old, 09-26-2013 15:56:59
Usually #1 is a small (20 ga ?) white wire and #2 is a larger (14 ga)red wire.
Jon Hagen
09-26-2013 20:06:48
 Re: 6volt conversion in reply to Jon Hagen, 09-26-2013 19:55:22
One other possibility, remove the regulator plug and look down the hole into the alternator at the two regulator blades. A few regulators have a little metal web connecting the blades together. If your regulator has this little metal web connecting the two regulator blades, and the #2 blade is connected to the BAT stud, it will keep the field energized and kill the battery in a couple days.
When used with the #2 "sense" wire connected to the battery stud, that connecting web between the blades must be cut away to stop the battery discharge.
Russ Crawford
09-26-2013 16:21:53
I found the raised numbers and I have them hooked up correctly. Anyother ideas? Thanks Russ
Janicholson
09-26-2013 20:26:04
 Re: 6volt conversion in reply to Russ Crawford, 09-26-2013 16:21:53
The diode bridge inside the alternator (not the regulator, which is separate) can be conductive both ways if bad or going bad. The check it take out the two small #2 and #2 terminals. Remove the wire from the big stud and put a volt meter between the stud and the wire terminal. If it reeds less than 1/4 volt it is probably OK. If more it is an indication of a bad rectifier bridge. Jim
Russ Crawford
09-27-2013 08:42:52
 Re: 6volt conversion in reply to Janicholson, 09-26-2013 20:26:04
Thanks to everyone who has taken the time to share their knowledge. Russ
old
09-26-2013 19:12:57
Could be a bad new alternator seen that many times over the years and seems to be getting worse now days
