TractorLinks.com
Tractor Talk Discussion Forum
Re: 6volt conversion
old
09-26-2013 15:39:09
Delco 10si alternator??? Do you have the 2 wire plug hooked up so the #2 wire goes to the big charge stud on the alternator and the #1 wire with the diode going to the side of the switch that is the ignition side?? If you hooked it up to the always hot side that is your problem and you may have burned out the alternator also
Russ Crawford
09-26-2013 15:50:10
 Re: 6volt conversion in reply to old, 09-26-2013 15:39:09
I was not sure how to tell was the # 2 wire so I hooked it up like the picture with the #2 wire on the right facing the back of the alternator. The alternator does charge when the engine is running. Thanks for responding. I hoped you would. Russ
soundguy
09-26-2013 16:51:24
 Re: 6volt conversion in reply to Russ Crawford, 09-26-2013 15:50:10
DEFFINATELY ensure you have #2 tot eh charge stud, and #1 to the SWITCHED side of your ignition
old
09-26-2013 15:56:59
On the alternator is self there is raised numbers that are #1 and #2. As far as which is which I do not know but if you have the 2 wire plug that you buy at say O'Reilly's I could go out and look and see which wire/color is which
Jon Hagen
09-26-2013 19:55:22
 Re: 6volt conversion in reply to old, 09-26-2013 15:56:59
Usually #1 is a small (20 ga ?) white wire and #2 is a larger (14 ga)red wire.
Jon Hagen
09-26-2013 20:06:48
 Re: 6volt conversion in reply to Jon Hagen, 09-26-2013 19:55:22
One other possibility, remove the regulator plug and look down the hole into the alternator at the two regulator blades. A few regulators have a little metal web connecting the blades together. If your regulator has this little metal web connecting the two regulator blades, and the #2 blade is connected to the BAT stud, it will keep the field energized and kill the battery in a couple days.
When used with the #2 "sense" wire connected to the battery stud, that connecting web between the blades must be cut away to stop the battery discharge.
Russ Crawford
09-26-2013 16:21:53
I found the raised numbers and I have them hooked up correctly. Anyother ideas? Thanks Russ
Janicholson
09-26-2013 20:26:04
 Re: 6volt conversion in reply to Russ Crawford, 09-26-2013 16:21:53
The diode bridge inside the alternator (not the regulator, which is separate) can be conductive both ways if bad or going bad. The check it take out the two small #2 and #2 terminals. Remove the wire from the big stud and put a volt meter between the stud and the wire terminal. If it reeds less than 1/4 volt it is probably OK. If more it is an indication of a bad rectifier bridge. Jim
Russ Crawford
09-27-2013 08:42:52
 Re: 6volt conversion in reply to Janicholson, 09-26-2013 20:26:04
Thanks to everyone who has taken the time to share their knowledge. Russ
old
09-26-2013 19:12:57
Could be a bad new alternator seen that many times over the years and seems to be getting worse now days
