Kubota B2200 3 cylinder diesel tractor questions
old
Well a friend show up with one just a little bit ago. Hyds do not work has 4 flat tires and he wants me to fix it up. Also has a 4 foot side winder brush hog on it and loader. Controls are very stiff on the loader. Need info like where to check the hyd fluid level and where to fill. Figure UTF should be ok in the hyds front drive and rear and transmission. Rotella for the engine.
Thanks
if memory serves correct there is a dipstick by where the top link hooks for hydros....make sure that the hyd oil you have is Kubota UDT compatible...they are a great little tractor, little tractor being the key word...rotella is good for the motor oil,
