Harry Keller
After having fuel tank of for repair and filling steer box with lube by the time i got tank re installed grease was running out of steer box and find it is coming from the seal on the side of box case..Want to add some seal softener mixed with lube so can i pour it down the steering shaft housing and would it get down into the steering box..There is a small bolt in the steering shaft tube below the steering wheel and wonder if it may have been put there by someone for that purpose.. Harry KellerPS Just do not want to remove tank again and can not get at fill hole with tank on..
