Need A Blank Rim
Bryce Frazier
Hey guys I need some help, I am desperately trying to find a blank 4.50 - 16 rim. I have a center, but don't know how to find the correct rim??? Not even sure if that was the right size! It is for a plow and will have a 5.50 x 16 traction tire on it. Does anybody have one of these rims, or know where I can find one at a reasonable price. Thanks, Bryce
Maybe one off a camper or trailer that hooks on with clamps? Maybe one off like a Farmall H front end? I think they are 16"
why not just use the front rim of w4 or h farmall tractor. then u can weld your centre in.
I have bought 16" blank rims from the same local company that I buy my wagon tires from. Check with your tire supplier. I had the spokes from worn out wheels welded into the new blank rims. Worked great. I believe the blank rims were around $55 each.
Fill in the blank what are you going to put this on?? With that info maybe some one has the correct rim so you will not have to make one from parts
try Nolts Tire in NY. I got 10x24 flat base blank centers rims for $97.00 each. May be worth a try.
a bit cheaper than some of the others.
