Algae in Fuel
FBH44
Have a diessel I run very little, onlyuse 15 gallons fuel a year or so. Is algae growing in there something to worry abouit? Should I add sometrihng to prevent it?
(reply to post at 05:26:50 08/22/13)
Algae requires water so if you keep water out of the diesel you should have no problems. I've been custom hay baling since '87 storing diesel in a 500 gallon tank and I've never had an Algae problem. There is a fuel conditioner available with bio-cide to combat Algae.
I cultivated about 900 gallons of algae in the home heating oil a couple years ago. No water in the tanks, no real old crap, it all grew from a tainted batch that was delivered in early summer. Apparently, if you use the fuel fast enough, you might not even notice... as it sits in heat all summer...it grows and grows. Natural sulpher used to control this prehistoric bacteria, that is all removed nowaday for pollution laws
I get this 'biocide' from NAPA. A quart jug does my winter's supply. Not cheap, but neither is the alternative...
