TractorLinks.com
Tractor Talk Discussion Forum
Re: Burned Metal
Robert Major
08-20-2013 20:01:04
Hi I worked in a wreckers for a while. The only time we questioned parts from fire damage was if it had got so hot, aluminium parts had melted from near the other stuff we wanted, and things got so hot they may be warped. Or it was a cab frame or roll bar, and needed to be structurally sound for safety. They automatically got bent with the big cat bucket, and went straight in the scrap pile!. so i'm guessing if burnt it would be ok if you can't see cracks in the rest of it and there is enough left for reasonable strenght. I would hope if it burnt the bearings got replaced not just re greased as I've seen before!. Has that tractor ever had a loader/ blade fitted, i seem to remember guys breaking front axle parts on certain 4010 and 20 series. They got fed up with this after the second time. Then came in for 5020 front axles and put them on. The track is wider and I think they used the rims to, as I seem to remember the hubs being bigger, It looked wrong, but you would have a hard time snapping that axle off. so I'm wondering if it got used parts from a wreckers to fix it back to original when something failed. Could also be the parts spent a lot of time in farm yard manure to and corroded bad as another thought.
Regards Robert
