eurocardan pto shaft ID
mite-help
Hi all--I have a couple of triangle pto shafts that need new tubes. looking for info to determine the #. one is for a light-duty 5' cutter. other is pretty heavy duty; unsure what it came off of. unless i'm missing it, don't see any markings. thanks--
I had a similar problem when I needed a new shield for one of our triangle shafts. I took it to a short line machinery dealer and he had a set of cards that he could match it up to so he could determine the number. As I recall the one I have is a Bondioli and Pavesi (sp?) but they had several numbers (1, 2, etc) that needed to be determined by matching it up to a card. Good Luck!
Lon
Drive-lines (dot) com might be a good reference for you, left menu ag pto, then right side B&D--tube profiles. I have some others in my favorites (if I can find them!?) if this one doesn't work.
