loader problem
Chris L.
New User
I have a New Holland TV140 with a 7614 loader and i am having problems with chatter and jerking with the loader. Other implements seem to work fine - round baler door goes up and down fine and rake and moco move in and out fine. I have changed tips on hydraulic lines with no improvement. Any ideas or help would be greatly appreciated.
Thanks in advance,
Chris
checked the fluid level underneath the tractor while it's running? Any leaks in packing? Loader uses way more fluid than the implements, so new filters & fluid? What made you think hyd. line tips would effect the cavitation? Chatter & jerking only when loaded or when empty? Only when going up or down or in both directions?
I have checked fluid level - its good. We have new fluid and filters and they have been changed regularly. No leaks. It does it up and down but if you "float" it down it will come down smooth. It chatter and jerks loaded or not but every once in a while it works normal -very rarely. We changed tips because we thought the flow may be getting impeded.
