Rats taking over
I've been working on a "41 9N Ford, trying to get it set up for some trail rides this fall. I had to replace the rear axle seals, clean the brakes, overhaul the governor, rebuild the carb, clean the fuel tank and sediment bowl, new steering joints, drivers seat, umbrella, lights front and rear (brake lights are rigged on a flasher), added rear seat and ice chest holder. Swapped for the turf tires. Added a Sherman Step-up and finally got it just about to run with the "Big Boys", then it looks like the rats are tying to take it over.
good work, looks fun. rear passengers will be grateful for the turf tires. i would consider some front end weight.
I hope you extended the exhaust tailpipe so your passenger does not get sick from fumes. People have got sick riding tobacco setters before from underslung exhaust,breathing it all day. Most tractors used for setting have upright exhaust, probably for this reason Mark
