Case 930 electric fuel shutoff solenoid part or way to bypas
I have a bad electric fuel shut off solenoid on case 930 1967 CK.
Need to find a used unit or a way to bypass completely.
It is a 62 series gasoline with magnetic fuel shut off.
Case part number A 32617.
Any suggestions would be appreciated.
On an IH you just cut off the needle plunger so that it doesn't occlude the hole. If you are like me you will fix it right after you get tired of the dieseling.
