TractorLinks.com
Tractor Talk Discussion Forum
Re: I've got problems...
Armand Tatro
07-29-2013 16:55:07
First of all to check your temp. gage sensor put the sensor in a pot of water and heat I to just above boiling by stages and using a cooking thermometer to check the readings on the gage. Second before you get too excited about the popping in the rear end CHECK ALL WHEEL BOLTS AND WHEEL WEIGHTS for loose bolts and/or wedges. If it is popping in every gear as you say loose wheels and/or weights would be common to every gear. Please post back with your results of these tests. Armand
Tim Workman
07-29-2013 18:41:20
 Re: I've got problems... in reply to Armand Tatro, 07-29-2013 16:55:07
I tightened all of the wheel bolts the other day but the popping still occurs. The bolts around the hub haven"t been touched in over 30 years. They didn"t seem loose at the time but I will have to check again
