Here you go. I made a mistake on the first posting and it's corrected in this one I think Click on the link to see the original posting
For those of you who like to build your own attachments.
Category 1 Specs on the machine.
Upper hitch point........inside width.....1.75" outside width..... max......2.75" hole diameter....3/4"
Lower .......pin dia. ...7/8" lower pin width.....26 3/4" Mast height pin center to pin center 18"
Category 2 machine specs.
Upper Hitch point......inside width.......2" outside width.....max.....3"+ hole diameter.....1"
Lower.........pin dia. ...1 1/8" Lower pin width.....32 1/4" Mast height pin center to pin center .....18"
Category 3 machine specs.
Upper hitch point......inside width........2"+ outside width... max......3 3/4" hole dia......1 1/4"
Lower........pin dia.....1 7/16" Lower pin width....38" Mast height pin center to pin center 22"
Category 4 machine specs
Upper hitch point......inside width....____ lower pin width.... 46" Mast height..........._____
Lower pin dia.......2" Lower pin width.....46" Mast height pin center to pin center.......______
Category 0 specs on the machine
Upper hitch point ......inside width.....2" outside width.....2 3/4" hole diameter.....5/8"
Lower pin dia........5/8" lower pin width.....20" Mast height center to center......13 3/4"
Notice the blank spaces on category four no machines around here that big. Other dimensions taken from machines in the back yard and on a lot bigger place than mine. The lower pin width is the shoulder to shoulder width on the pins you use.
3 POINT HITCH SPECIFICATIONS
