Ferguson TO-30 Lights?
Bryce Frazier
Hi guys it's Bryce. I have this Ferguson to-30, and am trying to figure out if it had lights or not? My dash looks a little different compared to others as well. Mine does not have an oil pressure gauge, but it does have the punch out hole on the far left of the dash for it, however it is not punched out? Right above that where I think the light switch should be is where the Distributor ON/OFF switch is, and other than that all I have is the temp and amperes gauges. I was just wondering if anyone has a picture of a factory correct dash, and also if these even came with lights on them? Mine has lights on the front only, but I think that someone just drilled a hole in the hood and stuck them in, to add to the confusion, I can't even find the switch, connection, or any other way to even turn them on!!! Any help would be great, I will try to get a picture of the dash soon, but it is currently being used by a neighbor to rake hay, best tractor in the world for that job! Thanks guys! Bryce
Found a picture of the front of the tractor so that you guys can at least see the lights! Thanks! Bryce
Hi Bryce-- just looked @ a to-30 I have, can't do a picture right now but here is my set-up: left of steering wheel is 2 std gauges, temp & amp-[temp to outside]. above temp guage is keyed ignition switch. above amp gauge is 'hump' sticking out of dash with light switch. [kinda believe ign. was here originally, but handy way it is.] RH side of dash has oil press. my lights are add-on. just install a toggle switch,in-line fuse run in from ampmeter out to lights. the hood doesn't ground very good, run grd. to frame- good luck!
