TractorLinks.com
Tractor Talk Discussion Forum
Re: Any big block Chevy experts?
Mark - IN.
07-06-2013 21:17:46
Bad head gasket will certainly cause it to overheat, and build pressure in the cooling system. Thermostat cools the engine by closing and allowing the fan blades to cool what is in the radiator until gets hot enough in the engine, opens the thermostat, lets cool antifreeze into the block, sends hot into the radiator, thermostat closes, fans begin the cooling process in the radiator again. Not having a thermostat, or having a bad thermostat will cause overheating as well. Overall, thermostat is perhaps the cheapest piece in the cooling system, and the easiest piece to change, and should be the first item changed. I just did one in my 4520 Deere a couple of months ago. Was out plowing all day, and then out of nowhere, overheated. Changed the thermostat, not a problem since. Thermostats go bad. Running without one, one that is stuck open or closed, or a weak one is not a good idea.
Good luck.
Mark
Mark - IN.
07-06-2013 21:43:49
 Re: Any big block Chevy experts? in reply to Mark - IN., 07-06-2013 21:17:46
I apologize. I just went back and reread your post and see that you changed the thermostat twice. But you also said that it onlt runs with the thermostat that you drilled a hole in too. That's not good. Are you sure that the thermostats that you tried are good? 195 degree thermostats? 160 degree do not allow cooling down properly, especially in the higher temperature electronic ignition egines. You could still have a bad head gasket or a crack somewhere, like a head, BUT that will cause overheating, and you WILL see built up pressure in the cooling system. If it is NOT really overheating, you could have a monitoring/metering problem that is causing some sort of safety to shut down. I guess that you really need to figure out if it really is overheating or not. Not losing coolant like blowing it out the exhaust? Not overheating because not leaking, losing, or blowing coolant into the overflow?
The thing that gets me, is that you say it will only run if you insert the thermostat that you drilled a hole in as a bypass. That's not a metering problem. That would suggest to me a need to relieve pressure and force cool coolant into the block, and I would expect to see physical overheating beyond the meter telling you that its hot. It also suggests a bad thermostat that is not opening, and now uses the hole you drilled in it to flow coolant at the same time it doesn't allow the radiator and fan blades to do their jobs. Those two thermostats you tried, you are sure that they are both good 195 degree thermostats? Try flushing the system, another new radiator, and if it still OVERHEATS beyond just saying that its running hot, go after the head gaskets IF you are sure that the water pump is good, and it sounds as though it is.
Good luck.
Mark
Mark - IN.
07-06-2013 21:48:27
 Re: Any big block Chevy experts? in reply to Mark - IN., 07-06-2013 21:43:49
"...try...another new radiator...".
Sorry, try another new thermostat (not radiator) after flushing, and then if it overheats, you got something bigger going on.
