TractorLinks.com
Tractor Talk Discussion Forum
Re: pto overrun coupler stuck, can't remove
tbish
07-06-2013 13:15:15
that thing that is split is a roll pin u need to drive it out then your overrun should slide off the roll pin mabe a little stuck hit it fairly hard use something a little smaller than the hole goodluck
tbish
07-06-2013 13:20:48
 Re: pto overrun coupler stuck, can't remove in reply to tbish, 07-06-2013 13:15:15
ps. the overrun should spin both directions I doubt that's the problem with your pto
papa T
07-08-2013 16:07:16
 Re: pto overrun coupler stuck, can't remove in reply to tbish, 07-06-2013 13:20:48
Thanks for the help.
Brian G. NY
07-06-2013 14:59:36
The over-running clutch should spin in one direction only when working properly.
You say the coupler spins in both directions "on the shaft".
If it spins on the shaft I would guess the roll pin must be sheared off.
If the roll pin is truly sheared off, it should be possible to force the coupler off the end of the shaft by either using a puller or a pry bar.
papa T
07-08-2013 16:05:43
 Re: pto overrun coupler stuck, can't remove in reply to Brian G. NY, 07-06-2013 14:59:36
Thanks for the help...PTO good...
