charging diode
NOT sure what you mean by "charging diode", but I don"t think it has one, outside of the ones in the alternator.
What issue are you having?
If you go to the FIAT dba CNH parts site, I believe the wiring diagram will come up in the parts manual. I don"t have time right now to go look, but I will later.
Also, I will look as as I have SOME Versatile shop manuals from that era.
Look up them FIAT parts
we are replacing the original alternator with a Bosch alternator. looking for the diode outside of the alternator that tells the alternator to "come on" thru the small wire to the alternator. will check out your suggestion, thanks
