Oliver 1550 3-point trouble
jjolivers
New User
Purchased Oliver 1550 that has 3-point that
will not lift? Power steering and front end loader
hydraulics work fine. Relief valve is closed and
all linkages are in order. Did note that self-leveling linkage was unhooked, hooked back up but no change.
You say the relief valve is closed. Do you mean that bolt down by your right heel is screwed in? Takes a 3/4 inch wrench,has a lock nut in against the casting.
Yes,that is correct. The loader has dual action
cylinders. I didn"t mess with the valve other than
to make sure it was closed.
Why don't you click on the Oliver forum and ask there. I've never had that problem on any of my 4 digits.
