Yesterday's Tractor Co.
Shop Now View Cart
Tractor Talk Discussion Forum
Re: Problem with JD 620
06-28-2013 20:31:10
Like the other guys said it's most likely the resistor, a two inch long ceramic thing that's behind the dash. Run a jumper wire around the ballast resistor. Just clip one end on the input side and clip the other end on the output side making sure both ends have good contact, or take both wires off and clamp them together. If it runs after you let go of the starter pedal its the resistor. Also it could be there's no power getting to the resistor from the switch. If the resistor is bad you will want to replace it before you run it much it because bypassing it will burn your new points in short order. Jim
