John Deere 36 ft hay elevator ?????
xcsp
Well the electric motor on my hay elevator was starting to give me trouble blowing the breaker , well just finished filling my loft and it started smoking , not good took it off and took to a electric repair shop they said it is unrepairable.
It was a Wagner Electric 1 1/2 horse motor
to replace it the guy said around $ 350.00
my question is would a gas engine be able to run this elevator ??
looked at harbor Freight they have a engine side shaft
for around $120.00
any Ideas on how big a motor I would need.
Thanks Greg
Just a guess, but I'd say about 5-6h.p. We ran a 32' with a 1h.p. electric without any problems for years. A lot depends on speed of the chain. With the one we had 3 bales on the chain was good load, more than that would bury the guy in the mow.
Tractor Supply in central Ohio has a capacitor run 1 1/2 hp for
$150.
Power isn't the only issue:
no sparks
easy starting
quiet
no running out of gas
just sayin'
A gas engine will run at 3000 rpm or more so how would you slow the drive down you will need a jackshaft more pulleys and soon you will have more in the gas drive than a new electric.
(quoted from post at 18:45:57 06/28/13) Tractor Supply in central Ohio has a capacitor run 1 1/2 hp for
$150.
no sparks
easy starting
quiet
just sayin'
thanks will check tractor supply
might be better to go that route
Greg
You will be messing around getting it to run after the first year. I agree with going back with electric. If you have a smaller tractor you could also put a PTO shaft on it. I have a Farmall A that's perfect for bale elevator duty.
Back in the day when hay was all small bales there were a lot of hay elevators with gas motors
Never heard of one starting a fire those briggs motors I think most were about 8 hp start every time put the right size pulleys on motor and elevator shaft they had power to spare fill elevator full of hay it will pull it
I'll keep a spare motor on hand for my elevator and grain augers that use electric motors. I pick them up cheap at Farm Auctions. I bring them home and check them out and have them ready to go. If a motor goes I have one sitting there to get me going again without allot of delay. I have seen them cheap on Craig's List too. Most the motors I got for 5-10 bucks when nobody's paying attention at an auction. If one doesn't work when I get it home its not like its a major loss.
We have a 1/2 hp 1800 rpm on our 40 ft conveyor, it used to be 60
ft. The bales get sent up butt to butt on a 45 degree.
We also have a 1/2 hp 3600 rpm on our 24 ft conveyor but it runs
very fast, hard to get more than 4 bales on it, usually only 2-3
bales.
