Propane 960 (newbee here)
Anonymous-0
Having problems with Ford 960 propane burner. The tractor runs good except when going over rough terrain. It will die and then I'm having a hard time getting it started. I was told that a regulator has a diaphram in it that will go bad after sitting for a long period of time. I have checked all wiring and it seems good.
Any ideas?
Where can I find propane parts?
Forklift repair or shop, I have an 850 on LP, but not factory, or I believe, has an impco vaporizer that you can rebuild, I would have to look at the shop manual book to see what the factory had as far as a vaporizer. It's going to be a spark or fuel issue, no doubt. I've had trouble with mine freezing up and not taking vapor in cold temperatures, and when going up slopes, so it was more or less a fuel system problem. One mine the coolant line is plumbed through the vaporizer so that it warms the LP, so the coolant level needs to be up, as well as the thermostat functioning properly and so on. The local forklift outfit raked me over the coals for the darned rebuild kit, I will not buy from them again, found it on the web, same exact OEM part for over $120 less, they can rake the warhouses, trucking outfits and similar over the coals, not me though LOL !
