Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: john deere b motor running fast
Royse
06-23-2013 19:10:18
Slow down a minute.
Patsdeere gave you some advice on things to check which it
seems like you summarily dismissed.
Paul also gave you some things to check, as did TomA.
Take the time to check them. It's been sitting a long time.
Since you said you didn't go through the governor, I'm assuming
you haven't gone through many of the other parts too.
To your question, check for a vacuum leak at the carb, intake,
any where that it could suck air in.
I would tend to believe after setting that long it is something binding.
Do you have a manual so you know how to set the adjustments?
Name
06-23-2013 19:34:28
 Re: john deere b motor running fast in reply to Royse, 06-23-2013 19:10:18
Yes I have the original manual and newer one to. Tells all adjustments and I will check for binding again and also leak. I was assuming carb is reason it takes quite a few turns to get it started since Timing spark and compression are all good.
