TractorLinks.com
Tractor Talk Discussion Forum
Re: john deere b motor running fast
Paul from MI
06-23-2013 18:29:18
Describe how the problem started. From your description it sounds like a governor issue. As others have said, first check for binding of throttle/governor linkage. If that seems ok, disconnect the governor from the carb--then control engine speed with the carb by hand. If that is ok, then the problem is internal to the governor. One thing to check quickly is to remove the carb and check the throttle butterfly to be sure it hasn't come loose. Mag timing can make for hard starting , but won't cause engine speed issues.
:Name:
06-23-2013 18:38:39
 Re: john deere b motor running fast in reply to Paul from MI, 06-23-2013 18:29:18
dont really know how it started, tractor had been sitting for 15 years its my grandpas he and i have restored it, after engine had been rehauled and got it started for first time engine has been racing, i didnt touch the governor just pulled that cover off of it to check gear and made new gaskets for it, hopeing its not internally in governor i will try running the throttle control by hand
BushogPapa
06-23-2013 20:32:54
 Re: john deere b motor running fast in reply to :Name:, 06-23-2013 18:38:39
If you "Pulled the cover" off the Governor, you just may have opened a big can of Worms...
:Name:
06-24-2013 03:43:25
 Re: john deere b motor running fast in reply to BushogPapa, 06-23-2013 20:32:54
i would not even know where to begin if it is inside governor,
