Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: Farmall H Engine Swap
Owen Aaland
06-18-2013 11:50:55
With a complete engine you don't have to change anything on the front. The other things you will run into is the control arm on the governor is different and you will probably have to change the two rear left side head studs to be able to mount the throttle linkage bracket for the H. The H flywheel will bolt to the crankshaft so you can mix and match the clutch parts however it works best for you. A custom built clutch disk should be available without too much hassle from places like Hy-Capacity or Ag Parts.
Copyright © 1997-2015 Yesterday's Tractor Co.
