Anonymous-0
I have made the decision to put a metal roof on a farm house I own. Going to use standard pole barn metal. Low profile ribs I think. 29 gauge. Probably a gray color. Think I will hire this done. Contractor says he uses 1 by 4's screwed down to the roof sheating boards. House is 80 years old so it has 1 by 6 boards with a layer of wood shingles and a layer of asphalt. I think he said he would screw the 1 by 4's down with 2 1/2 inch screws. Tin would be screwed down on the flat surface not on top of the rib. Said he didn't ever put screws on the rib - just next to it on the flat. I said I didn't want this tin to come up so he said he could double the screws across the bottom. Would ring shanks or screws through the furring strips into the rafters be better?? How about 2 by 4's over 1 by 4's? Are these overkill??? What do you guys think??? Any better ideas??? How do you guys do it??? Don't ever want to do this again. Thank you.
