Noel Putman
OK, this may seem silly. Hear me out here. So I need some front wheel weights for a ford 801. I found a set but they do not seem that heavy (25 lbs a piece).
The center hub"s threads on an 801 Ford are just under 2".
Can I just buy a 25lb Olympic Weight Plate at Wally World, drill 4 bolt holes in it, and bolt it to the outside of the front rim? The Center hole on an Olympic Plate is 2". Then use the weights I found on the inside of the rim?
Thanks for the input.
