Yesterday's Tractor Co.
Shop Now View Cart
Tractor Talk Discussion Forum
Re: Ford Jubilee
05-12-2013 15:52:27
At the time of stall, check for spark immediately.
Do you have good spark to the spark plugs?
If not, do you have battery voltage to the coil ignition side of the coil?
If spark is good, does fuel run out the drain on the bottom of the carb
when you pull the plug? Let it run into a container for a couple of minutes.
Should run steady the whole time, not dribble. Check the captured fuel
for water/rust/dirt. If it's good, put it back in the tank if you want.
Once you isolate it to a fuel or spark issue it will be easier to troubleshoot.
