TractorLinks.com
Tractor Talk Discussion Forum
Re: AC clutch
Dick2
05-08-2013 11:50:46
Depends on what the real problem is and the type of clutch. Some clutches have a rubber center that breaks; pretty easy to replace that. Others clutches are more complicated. But then, there might be a problem with the compressor that caused the clutch to fail (maybe it seized up?). Check it out as best you can before you start buying parts.
Jon Hagen
05-08-2013 15:45:04
 Re: AC clutch in reply to Dick2, 05-08-2013 11:50:46
I had that experience with an 88 Caravan. Burned up the original compressor clutch and two more I replaced. I finally found that the compressor pulled so hard that any time high side pressure exceeded 230 psi, it would slip and burn the clutch. To my dismay, I found my replacement compressor with a new clutch, cost little more than the two new clutches I burned up on that old failing compressor. :(
