Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: ROOSA MASTER DB/DB2 PUMP PROBLEM
mark reneski
05-07-2013 15:11:57
WISH IT WAS THAT EASY, TOOK THE RETURN FITTING OFF THE PUMP HOUSING AND THE TOP PUMP COVER THAT THE FITTING SCREWS INTO THINKING SOMTHING IS IN THE PUMP. NOTHING WAS IN PUMP STILL SAME PROBLEM. THANK YOU FOR YOU REPLY.. MARK
Tx Jim
05-08-2013 02:57:18
 Re: ROOSA MASTER DB/DB2 PUMP PROBLEM in reply to mark reneski, 05-07-2013 15:11:57
As I previously stated check the fitting that return line attaches to on pump for blockage. If engine will un with bleeder open the check valve in fitting is plugged.
mark reneski
05-08-2013 07:50:38
 Re: ROOSA MASTER DB/DB2 PUMP PROBLEM in reply to Tx Jim, 05-08-2013 02:57:18
thanx tx jim and the other person that posted, that was the problem, i didnt know about the check ball was in there, it runs fine, i drilled out the fitting and it purrs like a kitten. you two were very helpful and once again thank you very much!!! mark
Copyright © 1997-2015 Yesterday's Tractor Co.
