Tw20 pulling air into the fuel system
Anonymous-0
TW20 is working fine on light work but in heavy works seems to be pulling air into the system but I cant fine where its happening anyone got any ideas?
Check the short flexible plastic fuel line/connections between the lift pump and injector pump. If you"ve never changed it, it"s probably time for a new one. Sit down when you write the check!
line from tank to lift pump is cracking, replace it..
and if it runs good when both tanks are full and runs bad when on bottom tank.. your lift pump is bad..
Guys, I'm new to the Ford scenes. I have a TW-25 with 2 tanks and a toggle switch. IS tank number 1 in the nose and tank two under the left side of the tractor/ How does this program work?
I think that's right. My TW35 has two tanks like that, but no switch. The switch on yours is just for the gauge anyway - the front tank gravity feeds into the tank under the steps, and then the lift pump pulls the fuel to the injection pump.
