TractorLinks.com
Tractor Talk Discussion Forum
Re: Grain Binder Operators
rabbit
05-07-2013 05:50:07
Never pulled one with horses, but have some experience with a small tractor. You can do fairly square corners just by turning tractor fairly tight at the corner, at just the right time. Need to be careful to keep out of the reel. Small wheel will pivot, or even go backwards a few inches.
Bull wheel is mounted on a vertical rack. A crank provided with the machine allows operator to crank wheel up/down. Probably want to crank it down while it is still supported by transport wheels.
KEH
05-07-2013 16:13:05
 Re: Grain Binder Operators in reply to rabbit, 05-07-2013 05:50:07
My recollection is that the bull wheel stayed engaged while turning. To adjust the cutting height, you cranked the bull wheel down and cranked the little wheel down also, leveling the cuting platfrom. Cutting height was given final adjustment by moving lever to tilt the front(with cutter bar) down. The lever was moved back up if you were approaching rocks. The whole binder was tilted, not just the cutting platform.
KEH
