TractorLinks.com
Tractor Talk Discussion Forum
Re: Case 1896 remote
pete 23
05-04-2013 14:09:41
If it only happens on this one cyl and you have not tried a different cylinder, the problem is in the male tip on the pressure side. If it happens with more than one cyl, does system go on high pressure when trying to lower imp. Does lever stay latched or jump back to neutral. If it stays latched you have a signal valve problem but I can't tell you exactly where to look for that. Also, if it is the male tip the lever will also not stay latched and will go back to neutral when trying to lower imp. Easy to tell if building pressure both way , just unhook hoses and see that lever latchs when tractor is not running, then start and it should not stay latch as pressure should kick it off to neutral.
