TractorLinks.com
Tractor Talk Discussion Forum
dry ice and bearings?
mmidlam
05-03-2013 12:16:42
I am replacing a wheel bearing in a hub that appears to be a thermal fit. A 10 ton press couldn't move the race, so I welded a bead on the race. They are normally replaced as an assembly. I have the ideal to freeze the bearing in dry ice and heat the hub to about 200 degrees. will dry ice damage the bearing? Any advice?
David G
05-03-2013 18:05:03
 Re: dry ice and bearings? in reply to mmidlam, 05-03-2013 12:16:42
It is a standard practice on Homogenizer valve seats to pack them in dry ice, then install and let warm up.
Switchflicker
05-03-2013 17:11:51
 Re: dry ice and bearings? in reply to fordfarming, 05-03-2013 12:16:42
We used to empty a C02 fire extinguisher on aircraft bearing races to shrink them a bit before sliding into place. Not sure how correct that might me now though
Sw
Tramway guy
05-03-2013 16:54:40
The press fit is almost always on the rotating part of the bearing, so what you have said makes perfect sense.
That said, dry ice will not hurt the bearing at all. Just make sure you clean the hub bearing seat thoroughly and check for any burrs before installing... you will be fine. Cooling alone should be enough, but heating the hub will not hurt.
vinnie/S.D.
05-03-2013 13:47:07
some cars you have to replace the hole hub
IaGary
05-03-2013 13:28:02
Did you try the new one for size yet?
It may be a couple of thousands smaller and slide right in.
Or a little polishing with emery cloth may do wonders.
Heating and cooling helps as well but should not be needed if all is clean and smooth.
Gary
Retired Farmer
05-03-2013 13:25:14
If you are trying to put the bearing back on a shaft, you want to heat the bearing in hot oil and then slip it on the shaft. If you are replacing the race in a wheel hub you should be able to drive it out with a punch unless there are some set screws or a snap ring holding it in. Don't know what you are working on but I have never had to use a press to take out a race.
