TractorLinks.com
Tractor Talk Discussion Forum
Re: 9N distributor
John Christy
05-02-2013 21:53:47
The distributor body stays hot on doing the bench test.
Now let me lay out my system and you can tell me if I have a bad hookup. The positive post from battery goes to frame. The negative goes to the starter. The positive post also feeds the switch which goes to the coil. So the coil receives + and the body is + so the motor is - from the lead to the starter. Now I need that electrical 101 to tell me what is wrong with this picture. The starter would not run unless the motor was ++.
Dell (WA)
05-03-2013 09:14:18
 Re: 9N distributor in reply to John Christy, 05-02-2013 21:53:47
John........would it surprize you to learn the starter motor don't care, positive (+) or negative (-) ground, it ALWAYS turns the correct direction to start yer engine. And yes, you can run yer 6-volt starter motor on 12-volts.
Would it surprize you to learn yer 1-terminal squarecan frontmount coil don't really care positive (+) or negative (-) ground either??? While it came 6-volt positive (+) ground from the factory, many neubie shadetree mechanics install it negative (-) ground just like their 12V-V8's. It will start and run just fine. .......Dell, yer self-appointed sparkie-meister
