Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: 9N distributor
soundguy
05-02-2013 16:45:42
electronics 101 at play here.
the points are the source of 'ground' for the coil. when they close, there is a complete circuit.
if you have that dizzy off in your hand and put power to the coil, and the points are closed.. the body of the dizzy will be at the same potential as the top of the coil
certaintly no mystery here.
have you checked key switch and resistor contacts.
reading voltage on a meter is 1 thing. haveing a good enough connection to conduict some current is another.
post back
John Christy
05-03-2013 22:09:08
 Re: 9N distributor in reply to soundguy, 05-02-2013 16:45:42
I made the check and the voltage at the cois is the same as at the body with points closed. Points open 1/2 the voltage at the coil.
Copyright © 1997-2015 Yesterday's Tractor Co.
