TractorLinks.com
Tractor Talk Discussion Forum
Re: Tractor that has set up awhile
Jec
05-02-2013 11:09:38
Thanks, I"m pretty new with old tractors and didn"t know to put anything in cylinders until I read up on a stuck tractor. I don"t "think" it has set up too long. Gas is good, plugs look like a good running motor. No antifreeze in oil or oil in antifreeze, or water in motor. Guy I got it from got it in on a trade and he doesn"t know much about it other than what people told him. How much do you suggest to put in cylinders?
JerryS
05-02-2013 11:18:34
 Re: Tractor that has set up awhile in reply to Jec, 05-02-2013 11:09:38
Maybe you didn't follow what Soundguy said: automatic transmission fluid, type F.
JerryS
05-02-2013 11:23:16
 Re: Tractor that has set up awhile in reply to JerryS, 05-02-2013 11:18:34
Jeez! I misread what you said!
Anyway, I think a couple of tablespoons in each cylinder is about right. Again, whatever amount, just make sure you squeeze it back out.
Jec
05-02-2013 11:24:56
 Re: Tractor that has set up awhile in reply to JerryS, 05-02-2013 11:23:16
Thanks! I'll give it a try.
Jec
05-02-2013 11:22:31
I got the atf type f. I asked how much?
soundguy
05-02-2013 15:27:03
 Re: Tractor that has set up awhile in reply to Jec, 05-02-2013 11:22:31
split the quart between the 4 cyls, and save some for the gas tank and the oil.
a few ounces in each cyl is plenty.
adding it to the gas will help upper cuyl lube.
adding it to the oil prior to change.. but after running, will help witht he drain out.
on a new to me machine.. I have added 1/4 quart to a gallon of gas for testing. 1 quart in crankcase. and another quart split betweent he cyls.
atf is cheap and decent stuff.
Old Popper
05-02-2013 15:30:33
 Re: Tractor that has set up awhile in reply to soundguy, 05-02-2013 15:27:03
The John Deere 40's that I have seen are two (2) cylinders. LOL
showcrop
05-02-2013 18:16:40
 Re: Tractor that has set up awhile in reply to Old Popper, 05-02-2013 15:30:33
Us Ford guys all know that those putt putts really have four cylinders but are actually missing on two!!
soundguy
05-02-2013 15:42:54
and? what's the big deal on a typo?
if he can't figure out how many cyl's it has. he needs to hang it up before he starts.
Old Popper
05-02-2013 16:30:30
 Re: Tractor that has set up awhile in reply to soundguy, 05-02-2013 15:42:54
Don't get your whity tighties in a knot. Just funnin a little. Could always divide by 2 twice.
old
05-02-2013 12:01:56
I use any type of ATF and since I have Chev truck I use the Dextron type of ATF and has worked just fine for over a decade and I have freed up many struck engines with it
