Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: new life for old solenoid
John T
04-30-2013 04:34:25
Since its simply passage of current through the coil that creates a magnetic field to pull that plunger down, 6 volts will likely still create a strong enough field to engage it BUT I CANT GUARANTEE THAT it depends on the return spring pressure etc etc. Likewise, if its a 6 volt solenoid and you apply 12 volts you can bet that will engage the plunger and so long as the time period is brief I doubt the extra current will overheat or burn up the coil windings BUT AGAIN NO GUARANTEE. I'm talkin basic theory here and without specific detailed specs and data one just cant say EXACTLY how long or how well these variations will work/last. Its the kind of thing Ive done for years on the farm with no problem but I dont want to be blamed if farmer Billy Bob does it and burns up a solenoid. Being both an engineer and lawyer is a curse sometimes lol lol
Best wishes John T
NCWayne
04-30-2013 09:10:44
 Re: new life for old solenoid in reply to John T, 04-30-2013 04:34:25
Typically a 6 volt solenoid, or starter, will work nearly as long, if not longer, than a 12 volt will, when used on a 12 volt system. My go to guy at our local rebuild shop told me this years ago when we had the starter on Dad's 440IC Deere rebuilt. We had taken the starter in to get the start switch replaced and asked him to check out the starter (ie change the brushes, replace the bearings, etc) while he had it. When we picked it up he asked wether we were running it on 12V or 6V as the starter was wound for 6V. At the time Dad had had the machine for nearly 10 years, and it had been converted to 12V long before we got it.
What he told us was the insulation on the 6V windings was heavier than what was on the 12V. As a result it could withstand the lower amperage necessary when running on 12V where a 12V starter didn't have the necessary insulation to handle the higher amperages necessary to run on 6V.
Like I said we were told that probably 10 years ago and Dad had had the machine for several years already at that time. So, right or wrong, a 6 volt starter had worked just fine for us for over 10 years with absolutely no problems, and I'd have to assume that the coil on a solenoid would do just the same. The only thing is that with 12V to a 6V widning, it would tend to pull in harder, which may or may not shorten it's life.
John T
04-30-2013 10:04:23
 Re: new life for old solenoid in reply to NCWayne, 04-30-2013 09:10:44
Similar, Ive ran 6 volt starters at 12 volts on plenty tractors over the years (farmer and tractor dealer) and never had any problems either. It can be a bit tough on starter drives and teeth etc since it does kick in pretty hard. Its one application where perhaps you dont want the big heavy honkin battery and cables which can help with the above potential problem as it always turns over plenty fast anwway.... Another problem is if its a magneto ignition with 12 on a 6 volt starter she may spin so fast the mags impulse assembly becomes disabled n shes trying to start at the advanced run timing woooooooo hoooooooo that may be 25 BTDC versus the typical TDC used at cranking/starting speeds lol
Ive never had solenoid problems either but dont want to be responsible if farmer Billy Bob burns something up grrrrrrrrr
Fun chat
John T
Mark - IN.
04-30-2013 17:30:03
 Re: new life for old solenoid in reply to John T, 04-30-2013 10:04:23
Thanks fellas for the info.
I have an old AC-B that I use for mowing, 6 volt. I've been wanting to convert to 12 volt, but the only thing that I've been concerned with was the starter. Needing to get the coils around the armature rewound for 12 volt, but sounds like a non-issue.
Mark
