TractorLinks.com
Tractor Talk Discussion Forum
Re: More home electrical for a compote idiot
Greg K
04-28-2013 09:53:53
David has it right, you lost the neutral. As someone posted below, if your plugs and switches have the wires stabbed in the little holes in the back, this is likely your problem. It is just a matter of taking everything apart carefully and finding where you lost the connection. This will almost always be at a splice of some sort, either in a junction box, behind a light or switch, or in the panel where the neutral ties into the neutral bar. good luck
dcarp
04-28-2013 11:47:04
 Re: More home electrical for a compote idiot in reply to Greg K, 04-28-2013 09:53:53
I agree. I had a problem like that, circuit would work then not work, etc., etc. finally found a line into an outlet was just touching the outlet. When you put a load on it, it would spark & push the line away from the outlet. Take the load off and after 5 or 10 minutes the line would settle back and make a connection. I took all the outlets with the stab in connections out and replaced them with screw terminal connections.
No problems now.
