TractorLinks.com
Tractor Talk Discussion Forum
Re: Flourescent issue becomes a gfi issue?
Paul from MI
04-27-2013 20:35:31
It doesn't take much current from the hot to the grounding conductor to trip a ground fault, on the order of milliamps. I have never tripped on using a simple neon tester, but if you were using an incandescent bulb, as I used to, it would likely trip a GFI. There may be a GFI receptacle hidden in an unlikely spot feeding the receps that are dead. This is fairly common as GFI receptacle are cheaper than GFI breakers. You just have to start looking.
36 coupe
04-28-2013 02:50:06
 Re: Flourescent issue becomes a gfi issue? in reply to Paul from MI, 04-27-2013 20:35:31
My son inlaw is an electrician.He will only use gfi breakers.I have seen failures to trip on outlet types often.There are many parts that can fail in a gfi.A lightning strike on the power line will do it.Trusting a gfi can kill you.
