Tom N MS
Price was right so I bought it.. Now trying to figure out some things--#1 dual hyd lift levers..Per book the inner one(closest to seat) is suppose to lift and lower the implement---Inner one seems to do nothing --the outer one lifts and lowers the implement--reckon something is plumbed backwards???If I understand it right, the outer one is suppose to work external cylinder such as the one on the heavy box blade I got with the tractor.....Going down the road to bring it home, it would constantly lower itself about 10" then raise back up...any enlightenment on the two levers and the lowering and raiosing on its own?????? Also, what is the deal with the D, M, P lever down by the hyd lift levers? It is currently set on "P"..I simply want to use a bush hog behind it right now...Any enlightenment on this?? Thanks
The D-M-P
lever is for your draft control/ position control settings. the inner hyd lever is your three point lift control and the outer lever is your remote cylinder control, when plugging hoses into the couplers make sure they are all the way in and seated or they will not stay in place.
Where should D,M,P be set for bushhog? Something is backwards--my ouer lever(closest to tire) lifts/lowers the implement.
Where can I get shifter and other lever rubber boots? Thanks
If you google something like "Zetor tractor forum" you should find at least a couple of sites that have a lot of good info. There used to be a guy here in the Todays Tractors section form Canada IIRC that was big into Zetor too.
Bret-no luck finding Zetor forum yet. If u happen to see a link please let me know. Thank you.
http://en.zetor-club.com/
What was Zetor before it became Zetor? I can't recall anymore, Ursus maybe?
You can also hit some of the other tractor forums like tractor by net dot com or my tractor forum dot com for info. I'd give links, but that would kind of be spitting on Mrs Owner here, so I'll avoid that.
Zetor is an old original Czech tractor make. I believe I have seen models from early sixties or fifties on tractor shows here. Ursus and Belarus are different makes.
