Anonymous-0
The overdrive shifter is beating me up badly here, have adjusted it by the book and every other way I can think to, I can install quadrant shifter as directed in book have all gears when selected, I can go to the overdrive side and when I shift back to the low side/direct side of transmission I will not have the any of the gears to the left side of the quadrant, the sidling gear shaft pinion gear will not engage into the transmission drive gear, comes up just short of engagement, I can very easily move the gear on into transmission drive gear by hand, I do not see anything bent or excusive ware. Any help here would be appreciated. Thank you, Eric Leslie Juliette, Ga. 478 973 1932
