john deere 2010
The clutches are retained in the drums by the shifters(parts keys #13 #15)
I don't have access to a 2010 service manual but I think you need to purchase one.
SM2035CD Title:John Deere 2000 Series Tractors Marketing Code:Agriculture,Engines & Components Language:English Publication Type:
Associated Serial Numbers
Associated Models
$65.00 Qty
i have a service manual but its not that good do you no if you can split the tractor at the transmission without takeing the clutch houseing off the motor
Sounds as if you have an I&T manual which is not near as informative as the tech manual I listed. If you're going to attempt to repair the trans syncronizers it will be much easier for you if you get the JD tech manual. It's been a long, long time since I've seen one split but I'm fairly confident one can split the trans from clutch housing with clutch housing still attached to engine. I think the 2 bolts(parts key #27) must be removed through trans top cover hole.
