Yesterday's Tractor Co.
Shop Now View Cart
Tractor Talk Discussion Forum
Re: Weight ???
04-11-2013 16:32:10
Fluid, will make rims rusty, but its cheaper, and I think it gives more traction than wheel weights, easy to put in.
Wheel weights, always be able to resell, not any fun to put on, makes tractor wider, doesn't work the best if it hangs out on say a snowblower, not a big deal, they look cool
04-11-2013 17:40:54
 Re: Weight ??? in reply to G1355, 04-11-2013 16:32:10
Only time it will make a rim rusty is after it has a leak. I have a 41 Farmall B that has had calcium in the rears for most of its life & the rims are just fine.
04-11-2013 18:27:38
 Re: Weight ??? in reply to teddy52food, 04-11-2013 17:40:54
Come on guys fluid does not make tires pull better! It might lower the center of gravity a little. If you want to get beat just show up at a tractor pull with fluid in your tires!. Plowing 200 lb of weight on your left tire will out run the same tractor with 400 lb of fluid on the left. Because the tire will not contour itself to the ground. Vic
