Hydraulic christmas valve on Farmall M lift all
http://partstore.caseih.com/us/
Then pick find parts by model (top button)
Then pick Find by model (center icon)
Then pick Search (Not the brows button)
Put Farmall in the box
Select M
Select Hydraulics
select the box -- HYDRAULIC SYSTEM, REMOTE CONTROL TRACTOR ATTACHMENT, SPECIAL, AUXILIARY CONTROL VALVE & CONNECTIONS
Jim
Thanks for your instructions.After seeing the parts diagram my valve might be toast.The thimble (diverter ?)has rusted and i have not been able to disassemble the valve.It has been in an electrolosis tank several days,Not sure if that will loosen it up.May want to contact you again if that fails. Frank
Jim,need more information on valve.The valve seized up with rust.I used electrolosis to get the thimble freed,was able to get snap ring out, nuts off, and the spring out.There are some more parts i need to get out,I do not know what direction they come out as rust is holding them in.If you have any ideas, would you email me.Frank
