TractorLinks.com
Tractor Talk Discussion Forum
Re: Hydraulic christmas valve on Farmall M lift all
kevinj54
04-09-2013 17:08:02
It is on the case ih website
Frank whitehead
04-09-2013 17:18:47
 Re: Hydraulic christmas valve on Farmall M lift all in reply to kevinj54, 04-09-2013 17:08:02
Kevin,i tried that before i posted,guess i dont know how to access Case IH.Frank
Janicholson
04-09-2013 17:38:47
 Re: Hydraulic christmas valve on Farmall M lift all in reply to Frank whitehead, 04-09-2013 17:18:47
http://partstore.caseih.com/us/
Then pick find parts by model (top button)
Then pick Find by model (center icon)
Then pick Search (Not the brows button)
Put Farmall in the box
Select M
Select Hydraulics
select the box -- HYDRAULIC SYSTEM, REMOTE CONTROL TRACTOR ATTACHMENT, SPECIAL, AUXILIARY CONTROL VALVE & CONNECTIONS
Jim
frank whitehead
04-16-2013 20:18:07
 Re: Hydraulic christmas valve on Farmall M lift all in reply to Janicholson, 04-09-2013 17:38:47
Jim,need more information on valve.The valve seized up with rust.I used electrolosis to get the thimble freed,was able to get snap ring out, nuts off, and the spring out.There are some more parts i need to get out,I do not know what direction they come out as rust is holding them in.If you have any ideas, would you email me.Frank
frank whitehead
04-09-2013 18:53:26
Thanks for your instructions.After seeing the parts diagram my valve might be toast.The thimble (diverter ?)has rusted and i have not been able to disassemble the valve.It has been in an electrolosis tank several days,Not sure if that will loosen it up.May want to contact you again if that fails. Frank
