Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: Starter flywheel assembly on Farmall H tractor 1940
FBH44
04-08-2013 11:34:08
If you mean the same thing I had on my 1950 "H", the starter locking in place before it could spin the engine, I fixed mine by going to 12 volts. Mine used to just go "Cha-chunk!" from time to time, and lock the starter in place. Had to remove starter, jiggle it, and re-install to fix it. Switched from 6 volts over to 12 volts, and she really starts now. Never a problem.
rustred
04-08-2013 13:04:43
 Re: Starter flywheel assembly on Farmall H tractor 1940 in reply to FBH44, 04-08-2013 11:34:08
12 volt conversions do not fix starter jamming. in fact is harder on ring gear. burrs can be removed from ring gear with file or die grinder as a cheap fix.
charlie M
04-08-2013 11:38:13
As the problem gets worse it will hang up a 12V system too. I have 3 tractors converted to 12 volts and 2 of them will hang up once or twice per year.
