jd 2755 split
ricb
I have a 2755 with 20,000 hrs on it. the pto clutch has finally given out and to repair it the tractor needs to be split. i am wondering if any one has one of these tractors that they have split themselves. the bolts are out between the transmission and the rear end but can't seem to get the halves split and am wondering if there is a hidden bolt or something. this is my first shot at something like this but would have had 3 times the tractor's value if I would have sent it anywhere.
Are you sure you have all the bolts out??? There are two that are under the gear shift lever cover, inside the transmission case.
You have to have the gear shifters out for the transmission to come apart. The shift rails stick into the clutch housing.
