MH44 EFI Timing Wheel and pickup Coil
David G
I got the pickup coil mounted, will run this weekend and see if I get RPM.
Picture is upside down.
Very nice. We are restructuring a CNC vertical Mill so it runs Fanuc Code. I have been fabricating circuit board slide in mounts and stepper adapters. You do fine metal munching. Jim
I cannot take credit for the timing wheel, I bought that.
I cranked it over tonight and it showed about 250 RPM cranking, so that is right on target. I need to clean up the wiring then start it on carb and dist.
We worked on 4020 tonight, got that running.
